9 years, 1 month ago.
MBED OS 5 and LPC1768 RawSerial interrupt crash
I'm trying to get the serial port with mbed OS 5, RTOS and interrupts to work on a LPC1768.
So far I found the following post (https://developer.mbed.org/questions/76113/Error-attaching-interrupt-to-UART-on-LPC/). However the proposed solution doesn't work for me.
So far I tested the following code with mbed OS 2 and 5.
DigitalOut led1(LED1);
DigitalOut led2(LED2);
RawSerial pc(USBTX, USBRX);
void callback() {
// Note: you need to actually read from the serial to clear the RX interrupt
printf("%c\n", pc.getc());
led2 = !led2;
pc.attach(&callback);
while (1) {
led1 = !led1;
wait(0.5);
For mbed OS 2 the code is here
Import programLPC_echo
LPC1768 with mbed (2) and RawSerial test
and for mbed OS 5 the code is here
Import programLPC5_echo
LPC1768 with mbed OS (5) and RawSerial test
On mbed OS 2 everything seems to be running fine (without RTOS at the moment) but on mbed OS 5 LED1 stops blinking as soon as a single character arrives.
Since mbed OS 5 kept failing I also tried to debug it offline by using the keil demo and the CMSIS-DAP connection provided by the LP1768. However this resulted in the following messages:
Load "C:\\Keil_v5\\Code\\rtos_basic_uvision5_lpc1768\\rtos_basic\\build\\uvision5\\rtos_basic.axf" PDSC: Cannot recover from reset Error: Flash Download failed - Target DLL has been cancelled
Finally since I also have a NRF51 board on my desk I decided to try the same code with mbed OS 5 as well. In this case the test works without problems. The code is here:
Import programNRF51_Echo
NRF51 with mbed OS (5) and RawSerial test
However since I also need a USB host interface in the destination project this isn't a viable solution.
Any toughts on how to fix this?
Thanks in advance.
8 years, 9 months ago.
Hi everybody,
I have read your post because i have the same problem with a mtdot 868. I have replace Serial pc by RawSerial and my système doesn't work.
I have download the exemple "LPC5_echo" but it's doesn't work with my equipment.
Do you have an idée to resolve the problem ?
Thanks you
Hi everyone,
In general, you should not print from interrupt context. It takes a long time to do this and interrupt code should return as quickly as possible.
It's best to defer the print to the main loop using flags or the event loop.
