8 years, 9 months ago.
Which LED driver IC should I choose?
I want to installed a highlighted LED around 80-100 on a diameter of 120 mm PCB board. And I have to choose a LED driver first. Through research, I found the LED driver IC output amps should be larger than 1.2-1.5A. I want to know whether it is OK if I choose the IC among these... http://www.kynix.com/product/cate/124.html?
I have read the reference datasheet,and their max output amps is from 0.85-2.5A, may be I can choose one type of them? Will it be OK? Much thanks for your suggestion!
