9 years, 2 months ago.
Where is the ported LPCSPIFILIB code for the LPC4088?
Hi, I have a LPC40898 QuickStart Board and I'm trying to understand the QSPI code. I understand that the lowest level uses the LPCSPIFILIB driver ported for this board. For example I can't see the code that actually writes to the SPIFI control register CTRL. Could you point me at that code please? Many thanks Ant
The mbed-enabled LPC4088 QuickStart Board from Embedded Artists is a easy to use ARM Cortex-M4 rapid prototyping board in a standard through hole DIP package (44-pin), targeted at high-performance as …
