9 years, 2 months ago.
input voltage for I/O pins of LPC1768
Is the maximum voltage for a I/O pin is 3.3V or 5V in LPC 1768??
5V on everything except AnalogIn pins that are used as AnalogIn. (So if you use them just as regular pins you can go to 5V, but if you are using them for AnalogIn 3.3V is the max).
thank for the answer.. great help
posted by Harsha Karunanayaka 09 Jan 2017
