9 years, 3 months ago.
Export of FRDM-K64F fails "an error occurred during export. Contact support".
I have a FRDM-K64F with mbed-dev library. Any attempt to export fails with above error. I've tried KDS, GCC/embedded, also with and without all files checked.
I am using mbed-dev because mbed-src does not compile, and I want to export the library source files.
Is there any export that works for this board?
Hi Bob,
Sorry for the issues you are having, i'll try my best to help you out :)
I had flagged this issue before: https://github.com/ARMmbed/mbed-os/issues/3216
A fix is still forthcoming.
Can you trying reverting the revision of mbed-dev to an earlier one in the online compiler?
Andrea, team mbed
9 years, 1 month ago.
Arrrrgh! This issue is killing me!
Any way we can help out?
Workaround: publish the application to your account (private), import locally with mbed CLI (`mbed import http://developer.mbed.org/path/to/your/app`) and then export from there (`mbed export -i make_gcc_arm -m K64F`).
posted by 16 Feb 2017
