9 years, 2 months ago.
Configuring a LoRaWAN Sub-band for 915 MHz Hybrid Mode
Regarding: https://developer.mbed.org/teams/Semtech/code/LoRaWAN-NAMote72-Application-Demo/
How do I configure the channel mask to configure operation on the following sub-band?
Ch - Freq
8 - 903.9
9 - 904.1
10 - 904.3
11 - 904.5
12 - 904.7
13 - 904.9
14 - 905.1
15 - 905.3
I cannot find this in the code nor can I see any way to configure compiler options for the mbed compiler as I would in Keil uVision.
In config.h I see the following:
- Configure End-Device to use 8-channels corresponding to Block A
- Comment/Uncomment to disable/enable Hybrid mode
- define USE_BAND_915_HYBRID
- ifndef USE_BAND_915_HYBRID /*!
- Configure End-Device to use 64-channels across to Block A thru Block H
Does this mean that I can only use the first block of channels (CH 0 -7) Block A?
Thanks,
Frank
7 years, 9 months ago.
Hi Frank
Did you ever get this answered? Struggling with the same problem. Thanks.
Hi Alan, I just solved it!
Look in at the following path: mac -> LoRaWAN-lib -> LoRaMac.cpp
Look at line 2885. Here is what I changed:
Giving you a few lines before and after, original line commented out with the modification added on the next line
- if defined( USE_BAND_915 ) || defined( USE_BAND_915_HYBRID ) 125 kHz channels for( uint8_t i = 0; i < LORA_MAX_NB_CHANNELS - 8; i++ ) { Channels[i].Frequency = 902.3e6 + i * 200e3; modified by fcolumbu 07022018 for TTN standard Channels[i].Frequency = 903.9e6 + i * 200e3; Channels[i].DrRange.Value = ( DR_3 << 4 ) | DR_0; Channels[i].Band = 0;
Hope this works for you too.
posted by 03 Jul 2018
