9 years, 4 months ago.
about IMU
Iam using vectornav vn100 and I think its working fine. I can change the frequency and output data type and able to write to the sensor memory. But when I try to change the baud rate and write to the sensor memory Iam getting the error "we are sorry that sensor explorer has encountered a problem". Currently vn100 is working at 115200 baud rate. If I change to 9600 its showing the currently selected baud rate is too low to handle the output.
But my requirement is I have to achieve 921600 baud rate(the maximum). Iam not able to change the baud rate of vectornav vn100.
Also I tried to use the terminal in vectornav. In this Iam able to send the commands to the sensor but nothing is updated. I send the baud rate write command($VNWRG,05,921600*53) but vn100 not getting updated to the new baud rate.
I tried of uninstalling the software and installed the new version but the problem not solved. please anyone help me with this one.
