9 years, 3 months ago.
x-nucleo-ihm04a1 with 1 dc motor don`t work
j3 and j4 juper j1 and j2 open connect dc motor in A- and B- / A+ and B+
compiler ok
run motor for 2 second and run dc motor in one direction when RESET BUTTON PUSCH inibith function with USER SWITCH PUSH
  • @file Multi/Examples/MotionControl/IHM04A1_ExampleFor4UniDirMotors/Src/main.c
  • @author IPC Rennes
  • @version V1.0.0
  • @date May 16, 2016
  • @brief This example shows how to use 1 IHM04A1 expansion board with
  • 4 unidirectionnal Brush DC motors.
  • Each motor has one lead connected to one of the bridge output,
  • the other lead to the ground. The input bridges are not parallelised.
  • The demo sequence starts when the user button is pressed.
  • Each time, the user button is pressed, one new motor is activated
  • @attention
  • <h2><center>&copy; COPYRIGHT(c) 2015 STMicroelectronics</center></h2>
  • Redistribution and use in source and binary forms, with or without modification,
  • are permitted provided that the following conditions are met:
  • 1. Redistributions of source code must retain the above copyright notice,
  • this list of conditions and the following disclaimer.
  • 2. Redistributions in binary form must reproduce the above copyright notice,
  • this list of conditions and the following disclaimer in the documentation
  • and/or other materials provided with the distribution.
  • 3. Neither the name of STMicroelectronics nor the names of its contributors
  • may be used to endorse or promote products derived from this software
  • without specific prior written permission.
  • THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
  • AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
  • IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE
  • DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT HOLDER OR CONTRIBUTORS BE LIABLE
  • FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL
  • DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR
  • SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER
  • CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY,
  • OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE
  • OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
/* Includes --------------*/
/* mbed specific header files. */
  1. include "mbed.h"
/* Component specific header files. */
  1. include "l6206_class.h"
/* Definitions -------------*/
#define MAX_MOTOR (4)
  1. define MAX_MOTOR (2)
  2. define TimerUp (5)
  3. define TimerDown (5)
/* Variables -------------*/
static volatile uint16_t gLastError; static volatile uint8_t gStep = 0;
uint16_t TimeElapsed; uint16_t StartTime;
/* Initialization parameters. */ L6206_Init_t init = { L6206_CONF_PARAM_PARALLE_BRIDGES, {L6206_CONF_PARAM_FREQ_PWM1A, L6206_CONF_PARAM_FREQ_PWM2A, L6206_CONF_PARAM_FREQ_PWM1B, L6206_CONF_PARAM_FREQ_PWM2B}, {100,100,100,100}, {FORWARD,FORWARD,BACKWARD,FORWARD}, {INACTIVE,INACTIVE,INACTIVE,INACTIVE}, {FALSE,FALSE} };
/* Motor Control Component. */ L6206 *motor;
/* User button on Nucleo board */ InterruptIn mybutton_irq(USER_BUTTON);
Timer timer;
/* Functions -------------*/
  • @brief This function is executed in case of error occurrence.
  • @param error number of the error
  • @retval None
  • / void Error_Handler(uint16_t error) { /* Backup error number */ gLastError = error;
/* Enter your own code here */ }
  • @brief This function is the User handler for the flag interrupt
  • @param None
  • @retval None
  • @note If needed, implement it, and then attach and enable it:
  • + motor->AttachFlagInterrupt(MyFlagInterruptHandler);
  • / void MyFlagInterruptHandler(void) { /* Code to be customised */ /****/ /* Get the state of bridge A */ uint16_t bridgeState = motor->GetBridgeStatus(0);
if (bridgeState == 0) { if ((motor->GetDeviceState(0) != INACTIVE)|| (motor->GetDeviceState(1) != INACTIVE)) { /* Bridge A was disabling due to overcurrent or over temperature */ /* When at least on of its motor was running */ Error_Handler(0XBAD0); } }
/* Get the state of bridge B */ bridgeState = motor->GetBridgeStatus(1);
if (bridgeState == 0) { if ((motor->GetDeviceState(2) != INACTIVE)|| (motor->GetDeviceState(3) != INACTIVE)) { /* Bridge A was disabling due to overcurrent or over temperature */ /* When at least on of its motor was running */ Error_Handler(0XBAD1); } } }
/* Private functions -----------*/
  • @brief Button Irq
  • @param None
  • @retval None
void button_pressed(void) { mybutton_irq.disable_irq(); gStep++; if (gStep > MAX_MOTOR) { gStep = 0; } wait_ms(200); mybutton_irq.enable_irq();
  • @brief Main program
  • @param None
  • @retval None
  • / int main(void) { /*- Initialization. -*/
/* Initializing Motor Control Component. */ motor = new L6206( D2, A4, D5, D4, A0, A1);
/* When Init method is called with NULL pointer, the L6206 parameters are set */ /* with the predefined values from file l6206_target_config.h, otherwise the */ /* parameters are set using the initDeviceParameters structure values. */ if (motor->Init(&init) != COMPONENT_OK) exit(EXIT_FAILURE);
/* Attach the function MyFlagInterruptHandler (defined below) to the flag interrupt */ motor->AttachFlagInterrupt(MyFlagInterruptHandler);
/* Attach the function Error_Handler (defined below) to the error Handler*/ motor->AttachErrorHandler(Error_Handler);
/* Printing to the console. */ printf("Motor Control Application Example for 4 Motor\r\n\n");
/* Select the configuration with no bridge paralleling, two unidirectionnal motors on bridge A and two unidirectionnal motors on bridge B */ motor->SetDualFullBridgeConfig(PARALLELING_NONE_2_UNDIR_MOTOR_BRIDGE_A2_UNDIR_MOTOR_BRIDGE_B);
/* Set PWM Frequency of bridge A inputs to 1000 Hz */ motor->SetBridgeInputPwmFreq(0,1000);
/* Set PWM Frequency of bridge B inputs to 2000 Hz */ motor->SetBridgeInputPwmFreq(1,2000);
Attach button_pressed function to Irq mybutton_irq.fall(&button_pressed);
/* Infinite loop */ while(1) {
if (gStep > 0) { printf("Run motor 0 at 20%% of the maximum speed\n"); /* Set speed of motor 0 to 20% */ motor->SetSpeed(0,100); /* start motor 0 */ motor->Run(0, BDCMotor::FWD); StartTime = timer.read();
if(timer.read() - StartTime >= TimerUp){ motor->HardHiZ(0); gStep = 0; }
if (gStep > 1) { printf("Run motor 1 at 30%% of the maximum speed\n"); /* Set speed of motor 1 to 30 % */ motor->SetSpeed(1,100); /* start motor 0 */ motor->Run(0, BDCMotor::BWD); StartTime = timer.read(); if(timer.read() - StartTime <= TimerDown){ motor->HardHiZ(0); gStep = 0; }
if (gStep > 10) era 2 { printf("Run motor 2 at 40%% of the maximum speed\n"); /* Set speed of motor 2 to 40 % */ motor->SetSpeed(2,40); /* start motor 2 */ motor->Run(2, BDCMotor::FWD); }
if (gStep > 10) era 3 { printf("Run motor 3 at 50%% of the maximum speed\n"); /* Set speed of motor 3 to 50 % */ motor->SetSpeed(3,50); /* start motor 3 */ motor->Run(3, BDCMotor::FWD); }
if (gStep > 10) era a 0 { wait_ms(1000);
motor->HardHiZ(0); motor->HardHiZ(1); motor->HardHiZ(2); motor->HardHiZ(3);
wait_ms(1000); } } }
/**** (C) COPYRIGHT STMicroelectronics *END OF FILE/
