9 years ago.
SX1276lib/SX1276PingPong LoRaWAN bandwidth register setup is different from its datasheet ?
Accoding to SX127X datasheet (at pg112/113, depends on document version), its RegModemConfig1 in LoRa mode should have bandwidth configuration from 0x00 to 0x09, stands for following setup:
- 7.8KHz
- 10.4KHz
- 15.6KHz
- 20.8KHz
- 31.25KHz
- 41.7KHz
- 62.5KHz
- 125KHz
- 250KHz
- 500KHz
But in SX1276lib and its PingPong demo code, we can found only 125KHz to 500KHz is allowed in LoRa mode.
main.cpp
#define LORA_BANDWIDTH 2 // [0: 125 kHz,
// 1: 250 kHz,
// 2: 500 kHz,
// 3: Reserved]
<<code title=SX1276Lib/sx1276.cpp>>
if( bandwidth > 2 ) { Fatal error: When using LoRa modem only bandwidths 125, 250 and 500 kHz are supported while( 1 ); } bandwidth += 7; this->settings.LoRa.Bandwidth = bandwidth;
<<code>>
The bandwidth +=7 happens twice in SetTx() and SetRx() methods.
Is there any silicon revision and document support about that change ? Since I found some code was using narrow band like 10.4KHz BW.
