9 years, 3 months ago.
Unused pins in constructor
Hello all,
I created a small class for PWM motor control. In the constructor the hardware pins are defined like this:
DigitalOut dirPin, brakePin;
AnalogIn curPin;
motor2::motor2( PinName pwmPinName, PinName dirPinName, PinName brakePinName, PinName curPinName )
 : pwmPin( pwmPinName ), dirPin( dirPinName ), brakePin( brakePinName ), curPin( curPinName )
This works fine.
But: I don't need the brake and the cur pin in every of my applications. On all my applications i use in minimum 2 times this class and in some 1 with and 1 without. When I initialize these parameters with NC my application crashs.
How can I initialize this correctly?
PS: please excuse my bad english.
You can use NC as PinName, but you are not allowed to use a DigitalOut or DigitalIn variable if it has been instantiated with NC as the PinName.
I have used the following solution for this problem:
//constructor
TextLCD_SPI_N::TextLCD_SPI_N(SPI *spi, PinName cs, PinName rs, LCDType type, PinName bl, LCDCtrl ctrl) :
                             TextLCD_Base(type, ctrl),  _spi(spi),   _cs(cs),  _rs(rs) {
  // The hardware Backlight pin is optional. Test and make sure whether it exists or not to prevent illegal access.
  if (bl != NC) {
    _bl = new DigitalOut(bl);   //Construct new pin
    _bl->write(0);              //Deactivate
  else {
    // No Hardware Backlight pin
    _bl = NULL;                 //Construct dummy pin
make sure that pin is never used in the code without testing its validity:
// Set BL pin
void TextLCD_SPI_N::_setBL(bool value) {
    if (_bl) {
        _bl->write(value);
The DigitalOut pin must be declared in the class header like this:
//Backlight
    DigitalOut *_bl;
