9 years, 4 months ago.
STM32L062K8Tx RTC doesnot work after wakeup from sleep mode
Hello everyone,
I am using this function to set time set_time(ui32UTC);
I check and it works fine with this function: time_t seconds = time(NULL);
Then, i am using these two commands to put my controller in low power mode (Standby Mode):
HAL_RTCEx_SetWakeUpTimer_IT(sCfgData.RtcHandle, 5, RTC_WAKEUPCLOCK_CK_SPRE_16BITS);
/ Put MCU in Standby Mode*/ HAL_PWR_EnterSTANDBYMode();
where 1st function wakes up microcontroller after every 5 seconds.
Now the problem is that when i use these command after wakeup again time_t seconds = time(NULL); the seconds is a large negative value, what changes I need to do that it keeps the time even in standby mode.
Thanks
