9 years, 2 months ago.
power supply design for lpc1768
/calculation of 3.3 volts power supply for lpc1768? how to calculate load current when interfacing with multiple loads?
Ishita,
Thanks for the question.
So this is a relatively easy task. In essence what you need to do is place a low value shunt resistor(10mohm-1ohm) in series with your 3.3V supply and the rest of your loads. And then measure the voltage across this load to retrieve the current. I=V/R.
Have a look here for more information:
http://www.measurementest.com/2010/08/how-to-measure-current-using-shunt.html
Andrea, team mbed
