9 years, 3 months ago.
lpc1768 , canbus communicate ,lpc serial communicate
LPC1768 CAN BUS COMMUNİCATİON
CANT READ DATA FROM CANBUS LINE BY LPC1768
/media/uploads/satoglu/can_bus1.png
hii , ı want make canbus communication project. ı will read sensors by 2 atmega328p microcontrollers and send data to canbus line by mcp2515 module. ı made till that. then ı will take data by lpc1768 from canbus line. then ı will send data to computer(c# monitor) .But ı cant get data to lpc1768 from canbus line. ı use these codes at down. ı read some sharings here but ı could not solve my problem. my frequency is 500000 and first can ıd =1, and second canıd is =2. what ıs my wrong or what ı must to do? thanks for your help.
<< code >>
  1. include "mbed.h"
  2. include "CAN.h"
Serial pc(USBTX, USBRX); Serial uart(p28, p27);
CAN can(p30, p29); CANMessage msg; float signal;
int main() { pc.baud(9600); can.frequency(500000); can.reset(); CANMessage msg; create empty CAN message printf("received a CANbus message...\n"); Write to serial terminal
if(can.read(msg)) { pc.printf("CAN message received\r\n"); pc.printf(" ID = 0x%.3x\r\n", msg.id); pc.printf(" Type = %d\r\n", msg.type); pc.printf(" Format = %d\r\n", msg.format); pc.printf(" Length = %d\r\n", msg.len); pc.printf(" Data =");
if(msg.id==1){
for(int i = 0; i < msg.len; i++){ pc.putc(msg.data[i]); pc.printf(" %.2x", msg.data[i]);
}} else { for(int i = 0; i < msg.len; i++){ pc.putc(msg.data[i]); pc.printf(msg.data[i]); pc.printf(" %.2x", msg.data[i]);
signal = *reinterpret_cast<float*>(msg.data); pc.printf(" signal = %5.2f\r\n", signal); }} wait(0.1); } wait(0.1); } }
<</code>>
ı removed "CAN.h" lib. and ı am using uart . still same ,ı cant read data on canbus line.
posted by ibrahim SATOGLU 03 Dec 2016
Your code doesn't seem to have problems. Could you be more precise about your problem ? Are you sure that the ATmega send the messages (ie. did you check the CAN bus lines with an oscilloscope ?) Also, how long are your CAN bus lines ? Sometimes, only one 1 terminal resistor is needed (for short lines < 1m) and adding another one messes with the communication. If you're sure that the LPC1768 is the problem, then I'm afraid I won't be of great help...
ı built that circuit on board. canbus line is max 10cm.ı didn't check the CAN bus lines with an oscilloscope but ı can see data when ı use arduino mega2560 but when ı use lpc1768 , ı cant read data on canbus. ı tried all frequency (125000,250000 ,500000). also ı did a canbus example lpc1(send data) =>lpc2(receive data).but ı could not make that example. ı dont know what is my wrong or why ı cant read. :/
Emm... now that I take another look at your code, you did include a CAN.h lib. What is it ? You shouldn't need any additional librairie other than mbed.h to communicate via CANbus.
posted by Pierre David 03 Dec 2016
ı have started mbed yet for 2 weeks. ı saw an example so .also ı did .there is not a cause
