8 years, 11 months ago. This question has been closed. Reason: Unclear question
RTOS on STM32F429 not working after recent updates on mbed
Hi, I was using RTOS on STM32F429, and recently i got the massage that mbed was updated.When I put the updated version RTOS stop Working.I am here with sending the part of the code that i was used with previous mbed. Your Help is much appreciated.Thank you.
RTOS
#include "QEI.h"
#include "Timer.h"
#include "SDFileSystem.h"
#include "rtos.h"
//creating objects
QEI wheelR (PC_8,PD_13,NC,400,QEI::X2_ENCODING);
QEI wheelL (PE_2,PB_3,NC ,400,QEI::X2_ENCODING );
SDFileSystem sd(PF_9, PF_8, PF_7, PF_6, "sd");
Timer timer;
AnalogOut aoutR(PA_4);
AnalogOut aoutL(PA_5);
DigitalIn pb(PA_0);
DigitalOut led1(PG_14);
DigitalOut led2(PG_5);
Ticker tiker;
//Second Thread
void task2_thread(void const *args)
tiker.attach_us(&attime,400.0);
int main(void const *args)
Thread thread(task2_thread,NULL,osPriorityRealtime,(DEFAULT_STACK_SIZE*2.25));
osThreadSetPriority(osThreadGetId(), osPriorityIdle);
mkdir("/sd/mydir", 0777);
FILE *fp= fopen("/sd/mydir/sdtest.txt", "w");
timer.start();//max 30 min:reset after 30 min
while(!pb)
fprintf(fp,"%.6f %.2f %.2f %.2f %.2f %.2f %.2f %.2f\n",timer.read(),x_cmd,x_res,y_cmd,y_res,dynamicToqure_right,V,A_filterout);
led1=!led1;
fclose(fp);
aoutR.write(0.5);
aoutL.write(0.5);
timer.stop();
tiker.detach();
//ticker funtion
void attime()
led2=!led2;
Timepaste=timer.read();
pathGenaration();
Werror();
WpGain();
WdGain();
WiGain();
WPIDresponse();
InvJaco();
intigrate1();
intigrate2();
adaptiveControl();
error();
pGain();
dGain();
iGain();
response();
currentToAnaloge();
ResVelocity();
dob();
rtob();
jacobean();
deadRecko();
accelarationMeasure();
This is hard to follow with the missing details. Can you post your whole code using the
posted by Graham S. 28 Nov 2016<<code>> <</code>>tags? Or at least something complete, that is representative of the problem. task2_thread, has no infinite loop. This will execute once and the thread will terminate. Was this the intent? You can save yourself the trouble and just call a function. Then the while loop appears to have nothing to limit the rate that you try to write to the file. Just a guess, but you might run into problems if you try to just slam tons of data at the SD card all at once like this. I don't know what "pb" is, but will the while loop ever exit? If "while (!pb)" ever evaluates to 0, it looks like you will end up exiting your main function. I think this may cause undesirable behavior. Also I would look into recommended method for spawning threads. I believe the ctor you are using is marked as deprecated.I'm sorry for the missing details.I edited the code, I want to run one thread for my control loop for motors and it should be highest priority.I need to run that control loop at fixed sampling time, thats why I used tiker with 400us, each 400us that controlled loop needed to be run.If time remains from that loop, then I want to run the main thread, to data writing for SD cards. pb is a push button, and I need to stop all threads when I press push button.That is what I try to do with this code.Please guide me to accomplish the task in correct way.Thank you.
posted by Arunya Senadeera 29 Nov 2016
