9 years, 4 months ago.
External SRAM
Is mbed using the external SRAM for the stack ? I have ported the ebi test program from the CMSIS code and get some side effects. The ebi bank 0 seems to be initialized by the mbed code. The test is working, but some function calls to printf are scrambled.
The NuMaker Platform is an Internet of Things (IoT) application focused platform specially developed by Nuvoton. It supports ARM mbed OS 5.0 as well as Arduino interface, and is ideal …
Hi, NuMaker-PFM-NUC472 is equipped with 1MB external SRAM (0x60000000-0x600FFFFF). On mbed, it has arranged for some global/static variables/buffers and heap, and cannot be directly used for test program. The correct use of it is through heap allocation/deallocation (malloc/free in C and new/delete in C++) calls.
Looks like the external SRAM is for the heap and internal SRAM for stack and other data but there are a few object files that place data on the external SRAM too
https://github.com/ARMmbed/mbed-os/blob/master/targets/TARGET_NUVOTON/TARGET_NUC472/device/TOOLCHAIN_ARM_STD/NUC472.sct#L13
Yes, besides for heap, the external SRAM is also used for some global variables/buffers. It is because 64KB internal SRAM is insufficient for e.g. network application.
posted by cc li 21 Nov 2016
