9 years, 4 months ago.
Writing to file with sleep
I am making a temperature monitoring system that displays on a nokia 5110 lcd using a tmp102 temperature sensor. It works well but an issue arises when using sleep along with tickers, specifically when writing a string to a LOG.txt file with sleep enabled it gets stuck just before writing to the log file. It works fine without sleep at the moment.
#include "N5110.h"
#include "TMP102.h"
#include "RTC.h"
#include "FILEWRITE.h"
#define TMP102_R_ADD 0x91
#define TMP102_W_ADD 0x90
#define N5110_SCREEN_WIDTH 84
#define N5110_SCREEN_HEIGHT 48
void startLogging();
void stopLogging();
void writeTemperatureToFile();
void displayTemperature();
Ticker writeToFile;
Ticker DisplayT;
N5110 n5510Lcd(p7,p8,p9,p10,p11,p13,p21);
//BusIn buttonInput_bus(p17,p16);
DigitalIn A(p17);
BusOut ledBus(LED1,LED2,LED3,LED4);
TMP102 temperature(TMP102_W_ADD, TMP102_R_ADD);
FILEWRITE fileWrite;
RTC rtClock(1);
bool sleepMode = 0;
InterruptIn logSwitch(p18);
InterruptIn wakeScreen(p17);
n5510Lcd.init();
n5510Lcd.normalMode();
n5510Lcd.setBrightness(0);
temperature.init();
//float temp;
logSwitch.rise(&startLogging);
logSwitch.fall(&stopLogging);
wakeScreen.rise(&displayTemperature); //separate problem
//DisplayT.attach(&displayTemperature,7);
while(1)
sleep();
void startLogging()
n5510Lcd.clear();
n5510Lcd.setBrightness(0.5);
writeToFile.attach(&writeTemperatureToFile, 5.0); // THIS IS WHERE THE PROBLEM IS!!!
n5510Lcd.clear();
n5510Lcd.printString("LOGGING",0,2);
n5510Lcd.printString("ENABLED",42,3);
wait(2);
n5510Lcd.clear();
void stopLogging()
n5510Lcd.clear();
writeToFile.detach();
n5510Lcd.clear();
n5510Lcd.printString("DISABLED",36,3);
wait(2);
n5510Lcd.clear();
sleepMode = 0;
char logTemperatureString[6];
char logTimeString[20];
char logFullString[26];
temperature.getTemperatureString(logTemperatureString, 0);
rtClock.getLocalTime(logTimeString);
snprintf(logFullString, 26, "%s, %s\n\r", logTimeString, logTemperatureString);
fileWrite.writeDataToFile(logFullString);
sleepMode = 1;
char temperatureString[6];
char lcdStringBuffer[15];
n5510Lcd.clear();
//Print to lcd temperature in degrees celcius
temperature.getTemperatureString(temperatureString,0);
sprintf(lcdStringBuffer, "Temp(C): %s", temperatureString);
n5510Lcd.printString(lcdStringBuffer,0,0);
//Print to lcd temperature in degrees farenheit
temperature.getTemperatureString(temperatureString,1);
sprintf(lcdStringBuffer, "Temp(F): %s", temperatureString);
n5510Lcd.printString(lcdStringBuffer,0,1);
wait(2);
n5510Lcd.clear();
The filewrite class I created:
LocalFileSystem local("local"); // create local filesystem
FILE *fp;
BusOut fileLeds(LED4,LED3,LED2,LED1);
FILEWRITE::FILEWRITE()
// fileLeds = 15; // turn on LEDs for feedback
// fp = fopen("/local/log.txt", "a"); // open 'log.txt' for appending
// if the file doesn't exist it is created, if it exists, data is appended to the end
//fprintf(fp,"SESSION START:\n"); // print initial string to file
//fclose(fp); // close file
//fileLeds = 0; // turn off LEDs to signify file access has finished
void FILEWRITE::writeDataToFile(char fileData[])
fileLeds = 15; // turn on LEDs for feedback //IT GETS STUCK HERE!!!!!!!!!!!!!
fprintf(fp,"%s\n",fileData); // print string to file
