8 years, 11 months ago.
Initializing pins of BLENano at runtime: Base class for DigitalIn, DigitalOut and AnalogIn needed
I'm creating a firmware for BLENano with the mbed online IDE. I want to initialize pins of BLENano at runtime (I would like to configure them via Bluetooth), so I need a way to create an array or a map of generic pins. I searched within the mbed library for a superclass of DigitalIn, DigitalOut and AnalogIn classes and I found they all inherit from the same class "Base" (https://developer.mbed.org/users/screamer/code/mbed/file/aff670d0d510/Base.h).
This was great, so I immediately tried using the Base superclass in my code, to define my map
std::map <int, Base> initializedPins;
but unfortunately compilation failed with this message: - Identifier "Base" is undefined "std::map <int, Base> okPins
Even this simple assignment mbed::Base mytrimmer = new AnalogIn(P0_4);
fails with same message: - Identifier "Base" is undefined "Base mytrimmer = new AnalogIn(P0_4);
This should be a possible command in c++, isn't it? What am I missing? Why isn't the Base class defined?
Do you know of other ways to define an array of generic pins, which I can then initialize with different pin classes?
Thanks in advance, Giovanni.
