9 years, 5 months ago.
mbed CLI Compile error (target 'NUCLEO_L073RZ')
After importing successfully the Nucleo_blink_led program using the mbed CLI import command, I try to compile it locally for the NUCLEO_L073RZ target (GCC_ARM toolchain), but I face the following problem:
[ERROR] Attribute 'default_build' not found in target 'NUCLEO_L073RZ' [mbed] ERROR: "python" returned error code 1.
The problem does not arise compiling the same program for NUCLEO_F401RE target.
Could you please help me to solve this issue? Thanks in advance.
Regards, Luigi
Hi Luigi,
Sorry for the issues you are having :).
So this seems to be some strange issues with the latest revision of mbed 2.0. Rolling back the revision from 0ab6a29f35bf to 25aea2a3f4e3 seemed to fix this issue.
I am going to flag this issue.
For now, open the mbed.bld file in text editor and replace everything with:
http://mbed.org/users/mbed_official/code/mbed/builds/25aea2a3f4e3
Then use 'mbed deploy' to update libraries to this revision.
Andrea team mbed
If it helps any, I saw the same problem for the NUCLEO_F042K6 target, but could compile after the suggested workaround.
posted by Andy Breuninger 03 Dec 2016
