9 years, 4 months ago.
Who will fix the mbed system gmtime() function?
Today I discovered that the mbed gmtime() function is basically broken. I also then found someone else asking about this 2 years ago:
https://developer.mbed.org/forum/mbed/topic/5327/
Also someone else doing other work had to implement a work-around for this also two years ago:
https://developer.mbed.org/users/WiredHome/code/TimeInterface/docs/1de342fa7840/TimeInterface_8cpp_source.html
Seriously, did nobody test the basic system libraries during development?
It is really worrying from a point of view of eventual code quality and operational safety when your system-supplied stuff is broken. You know the stuff you normally should use instead of developing your own because it should have been thoroughly tested, and that nobody had fixed a reported problem in 2 years.
