9 years, 4 months ago.
mbed Dev question (Possible problem)
Background
We have been using a LPC824 with a GPRS module. We use the gprs modules command to send data to the url like AT+HTTPACTION or AT+PARA("url","http://xxx.com/abc")
The URL cotains a field that is originally in numberic format and we use sprint (with %d) to convert to a Char and do a puts(convertedVale) into the GPRS
Problem
When I use regular mbed library all is well. When we use mbed-dev (becasue we want to set the clock speed to about 6mHZ) the internet call doesnt go through.
Errors out with a HTTP RC of 603 which could either be a DNS error or a CONTENT TYPE error.
However if hardcode the value into the char filed and send it it works fine (even with mbed-dev).
I am wondering if the sprintf is messing up something
Best Regards
Surendar
All
To prove that it was sprintf with mbed-dev, we removed the sprintf and used our own conversion routine/module for int to character conversion and the system started to work again.
Summary
mbed + sprintf -> works
mbed-dev + sprintf -> doesnt work
mbed-dev + custom-wrinten convertor -> works
Best regards Surendar
posted by siva surendar 04 Jan 2017
