9 years, 4 months ago.
nrf51822 never sleeps with Serial declared
I have Seeed Tiny_BLE board with power monitoring circuit.
- Q1) How to turn off Serial port correctly?
- Q2) When compiler finds Serial initialization (see code below) it never put device to sleep (current consumtion about 1mA) . Even if this part of code will not be called. If I comment pc = new Serial(UART_TX, UART_RX); current cosumption is ok (10-20uA). So the question: is it possible to use sleep mode together with Serial port object?
#include "BLE.h"
#define LED_BLUE p23
#define BUTTON_PIN p17
#define UART_TX p9
#define UART_RX p11
DigitalOut blue(LED_BLUE);
Serial *pc = NULL;
BLE ble;
volatile bool bleIsConnected = false;
InterruptIn button(BUTTON_PIN);
void startUart()
void detect(void)
blue = !blue;
if (pc!=NULL)
startUart();
else
pc = NULL;
int main(void)
blue = 1;
button.fall(detect);
ble.init();
ble.setAdvertisingInterval(800); /* 100ms; in multiples of 0.625ms. */
ble.gap().startAdvertising();
while (true) { ble.waitForEvent(); }
Hi Klym,
It is not possible to put the serial to sleep with mbed primitives. This is a known issue (see here) which has to be resolved.
You can directly disable it as a workaround:
// include definitions #include "device.h" // disable the UART: ((NRF_UART_Type *) UART0)->ENABLE = (UART_ENABLE_ENABLE_Disabled<< UART_ENABLE_ENABLE_Pos); // enable the UART: ((NRF_UART_Type *) UART0)->ENABLE = (UART_ENABLE_ENABLE_Enabled << UART_ENABLE_ENABLE_Pos);
Vincent,
thanks for info. Seems this code is working but there is one condition: UART should finish to transmit all data before 'Disable'. Otherwise, for example if you have pc.printf("something"); disbaleUart(); UART will not work after wake up.
What I can also find, possible it's the best way:
//to disable UART
NRF_UART0->TASKS_SUSPEND=1;
//to re-enable UART
NRF_UART0->ENABLE = UART_ENABLE_ENABLE_Enabled << UART_ENABLE_ENABLE_Pos;
NRF_UART0->TASKS_STARTTX = 1;
NRF_UART0->TASKS_STARTRX = 1;
