9 years, 4 months ago.
Having problems compiling with newly installed mbed CLI
Hello all,
I am currently trying to compile the mbed_blinky project on my newly installed mbed CLI. I just want to make sure the binary work on my FRDM-K64F. However I currently get this error message (at the bottom) also given are the version returns from the various installed support clients for mbed CLI.
C:\Users\spms0\mbed_blinky>python version
Python 2.7.8
C:\Users\spms0\mbed_blinky>git version
git version 2.10.0.windows.1
C:\Users\spms0\mbed_blinky>hg version
Mercurial Distributed SCM (version 3.9.2)
(see https://mercurial-scm.org for more information)
Copyright (C) 2005-2016 Matt Mackall and others This is free software; see the source for copying conditions. There is NO warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
C:\Users\spms0\mbed_blinky>mbed version
0.9.10
C:\Users\spms0\mbed_blinky>mbed compile -m K64F -t GCC_ARM
[ERROR] Attribute 'default_build' not found in target 'K64F'
[mbed] ERROR: "python" returned error code 1.
[mbed] ERROR: Command "python -u C:\Users\spms0\mbed_blinky\.temp\tools\make.py -t GCC_ARM -m K64F source . build .\BUILD\K64F\GCC_ARM" in "C:\Users\spms0\mbed_blinky"
I can see that it is a problem with finding the target K64F and that causes python to return the error but I don't understand why this is a problem as the directory mbed_blinky has a directory mbed which contains a target directory for K64F TARGET_K64F.
If anyone could help me as to why this is happening it would be very appreciated.
I have the same problem. With the blinky code from ARM it is working, with my blinkycode which I published for test not.
https://developer.mbed.org/users/xdeschain/code/Nucleo_blink_led/
arm-none-eabi-gcc version
arm-none-eabi-gcc (GNU Tools for ARM Embedded Processors) 5.4.1 20160919 (release) [ARM/embedded-5-branch revision 240496]
Copyright (C) 2015 Free Software Foundation, Inc.
python version
Python 2.7.12
pip version
pip 8.1.1 from c:\python27\lib\site-packages (python 2.7)
git version
git version 2.10.1.windows.1
hg version
I had the same problem and posted an issue on github. The problem exists in the latest revisions of the mbed library. The solution is to use an older revision
https://github.com/ARMmbed/mbed-cli/issues/391#issuecomment-259932373
Sean,
Can you try update Python please, CLI was tested with 2.7.11.
Can you also tell me your version of the GCC_ARM.
arm-none-eabi-gcc
versionRegards,
Andrea
posted by Andrea Corrado 02 Nov 2016Hi Andrea,
Thanks for the reply. I updated my Python version and everything seems to have worked. Thanks for the help, I think I just accidentally overlooked the fact that the version was 2.7 in the video.
Kind Regards, Sean
posted by Sean Suttie 03 Nov 2016
