9 years, 4 months ago.
LM75B code problem
Hello, thanks for watching my question! when i compile the code about LM75
https://developer.mbed.org/components/LM75B-Temperature-Sensor/
Error: No suitable conversion function from "LM75B" to "float" exists in "main.cpp", Line: 67, Col: 41
i have no idea to solve orz~ what's wrong QAQ Thanks :)
https://developer.mbed.org/users/neilt6/code/LM75B/docs/7ac462ba84ac/classLM75B.html
You may need to use temp() function to get temperature data from the sensor.
#include "LM75B.h"
//Create an LM75B object at the default address (ADDRESS_0)
LM75B sensor(p19, p20);
    //Try to open the LM75B
    if (sensor.open()) {
        printf("Device detected!\n");
        while (1) {
            //Print the current temperature
            printf("Temp = %.3f\n", (float)sensor.temp());
            //Sleep for 0.5 seconds
            wait(0.5);
    } else {
        error("Device not detected!\n");
Thanks, but i try the code. The display always prints Device not detected. How could i solve it?
posted by jajn HA 31 Oct 2016
What kind of board are you using ?
LPC4088
With lpc4088 board, sda/scl are on pins : p9/p10 or p32/p31 has it is defined here : https://developer.mbed.org/platforms/EA-LPC4088/
posted by Raph Francois 31 Oct 2016
Thanks
