9 years, 1 month ago.
Problem with RS232 / sendig / reception
Here is my mbed code
// Hyperterminal configuration
// 9600 bauds, 8-bit data, no parity
//Declaration de la liaison RS232 sigfox
Serial sigfox(PC_12, PD_2);
    char c;
        if(pc.readable())
            c = pc.getc();
            sigfox.putc(c);
        if(sigfox.readable())
            pc.putc(sigfox.getc());
My problem is, when I send a character from my PC, it is not send to sigfox but to my PC
I'm using STM32 Nucleo L476RG
Any ideas ?
Thanks
Maybe the sigfox does receive the data and echoes it back to mbed which then returns it to the PC making it look as if the data never reaches sigfox.
Your code looks logically correct. However I might suggest some changes which you can try and see if it works correctly Note the use of RawSerial and sigfox.writeable, pc.writeable.
RawSerial pc(SERIAL_TX, SERIAL_RX);
RawSerial sigfox(PC_12, PD_2);
    char c;
        if(pc.readable())
            c = pc.getc();
            while(!sigfox.writeable());
            sigfox.putc(c);
           c = sigfox.getc();
            while(!pc.writeable());
            pc.putc(c);
