9 years, 1 month ago.
Using STM Nucleo with M4. Any way to stall SPI clock?
I am using the STM Nucleo 32F401RE to communicate with some hardware that has a two wire SPI interface. It takes a command and then some data, but the documentation states that it needs to stall the SPI clock line between changes of command and data. I am using the `HAL_SPI_Transmit` functions right now, and it's not working the way I assume it should.
I've checked all the connections and hooked up a Logic Analyzer and found that the data is being transmitted correctly, but the device is just not execting these commands due to the non stalling SPI clock.
