9 years, 5 months ago.
GR-PEACH BP3595 WiFi Sniffer
We'd like to use the GR-PEACH along with the ROHM BP3595 WiFi module to build a WiFi sniffer that will gives us all the MAC addresses in range, along with their RSSI.
I don't see any supported libraries that do this, and I've not even been able to even find a programming manual for the ROHM module. We can use any WiFI device, a USB device would work fine if it had a supported mbed library.
Any pointers or ideas are appreciated. We're on a short fuse, thus the need to find something that's already mostly supported.
Ed
When the "scan()" function added in mbed OS 5.2 is used, the following information can be acquired. BSSID will be usually the same one as the MAC address.
  • SSID
  • BSSID
  • Security
  • RSSI
  • Channel
Sample program
You can try with the following program.
[Repository '/teams/Renesas/code/GR-PEACH_WebCamera/' not found]
Using WiFi BP3595 (Set to "NETWORK_TYPE=1" and "SCAN_NETWORK=1")
https://developer.mbed.org/teams/Renesas/code/GR-PEACH_WebCamera/wiki/Homepage#using-wifi-bp3595
Relevant parts excerpt
main.cpp (relevant parts excerpt)
static void scan_network(void) {
    int num;
    int i;
    int select_no;
    bool loop_break;
    char ch;
    char pass[64];
    const uint8_t *wk_p;
    WiFiAccessPoint point[8];
    while (1) {
        printf("scan...\n");
        num = network.scan(point, 8);
        for (i = 0; i < num; i++) {
            printf(" No.%d\n", i);
            printf("   ssid    :%s\n", point[i].get_ssid());
            wk_p = point[i].get_bssid();
            printf("   bssid   :0x%02x,0x%02x,0x%02x,0x%02x,0x%02x,0x%02x\n",
                    wk_p[0],wk_p[1],wk_p[2],wk_p[3],wk_p[4],wk_p[5]);
            printf("   security:");
            switch (point[i].get_security()) {
                case NSAPI_SECURITY_NONE:
                    printf("NONE\n");
                    break;
                case NSAPI_SECURITY_WPA:
                    printf("WPA\n");
                    break;
                case NSAPI_SECURITY_WPA2:
                    printf("WPA2\n");
                    break;
                case NSAPI_SECURITY_WPA_WPA2:
                    printf("WPA_WPA2\n");
                    break;
                case NSAPI_SECURITY_UNKNOWN:
                default:
                    printf("UNKNOWN\n");
                    break;
            printf("   rssi    :%d\n", point[i].get_rssi());
            printf("   channel :%d\n", point[i].get_channel());
...omit...
#endif
Reference information
Software development specs of BP3595 Japanese
https://developer.mbed.org/teams/Rohm/wiki/Datasheet
