9 years, 5 months ago.
demos not compiling
several of the demos are giving me the following error. I have not been able to track this down. Error: Cannot open source input file "stm32f7xx_hal.h": No such file or directory in "BSP_DISCO_F746NG/stm32746g_discovery.h", Line: 48, Col: 28
any suggestions Thank you
8 years, 8 months ago.
Hi, This problem can be found in evaluation version of Keil MDK or IAR You can use free compilers
Can you be more specific on which demos are not working? It sounds like there might be a mismatch with the mbed lib and the latest release. You can try updating all libs and see if it compiles. I'll be glad to try on my board once I know which demos you are trying.
Thank you for your responce. The two that I am having trouble with are the clock demo and the sd demo. I just tried to update them both. with no success. I have also removed them and and reloaded them with a fresh copy. Both of these demos give me the same error. Thank you again for your help
posted by 20 Oct 2016
I found this demo https://developer.mbed.org/teams/ST/code/DISCO-F746NG_SD_demo/?platform=ST-Discovery-F746NG Which did not compile but for other reasons. If it is the same as you are trying I would post a comment on the Github website. As far as the clock, I found a demo with the RTC which worked without issue.
posted by Bill Bellis 21 Oct 2016
