9 years, 6 months ago.
Setting Clock for FRDM-K64F
I am Using a Mikroe C Pro Arm Compiler, need to set the Clock for the controller, tried setting 25MHz, 50MHz, 48MHz & 120MHz, I have a simple program that prints a string say "Hello", i see gibberish printed as that when Baud mismatch occurs, can any one advice what clock setting should i use.
When I tried using embed compiler I see no output, since I am using the Default UART connected on PB16,17 routed through USB interface was expecting to see output directly.
Thanks & Regards
Madhav
