9 years, 6 months ago.
High speed SPI data transfer - strange delay
Hello all,
I have two mbed boards (Nucleo and Renesas) talking to each other over SPI at 8 MHz just fine. However when I increase the frequency to 32 MHz, a SPI delay appears (or grows) which completely renders the data transfer useless.
Nucleo (master) operates with 216 MHz clock and Renesas Peach board is clocked at 400 MHz, so I wonder what causes this delay and what is the way how to work around it, please?
Picture below shows: A1 - 16 bit clock, A2 - data in 0x01
Any pointers towards solution would be great!
9 years, 5 months ago.
In GR-PEACH, internal clock that is used for the SPI is 66.666MHz. In the case of the slave, you can't communicate fast so much.
If the mode to 1, you can use the burst transfer. You can communicate continuously, so communication speed of the total should become speedy.
Master
SPI spi(P4_6, P4_7, P4_4); // mosi, miso, sclk
DigitalOut cs(P4_5);
uint16_t read_buf[30];
spi.frequency(5000000); // 5MHz
spi.format(16, 1); // 16 bits, mode 1
// Burst Transfer
cs = 0;
for (int i = 0; i < 30; i++) {
read_buf[i] = spi.write(i);
cs = 1;
// for debug
printf("%d ", read_buf[i]);
printf("\n");
Slave
SPISlave device(P4_6, P4_7, P4_4, P4_5); // mosi, miso, sclk, ssel
uint16_t resp = 0;
int i = 0;
device.frequency(5000000); // 5MHz
device.format(16, 1); // 16 bits, mode 1
device.reply(i++); // Prime SPI with first reply
while (1) {
if (device.receive()) {
device.reply(i++); // Make this the next reply
resp = device.read(); // Read byte from master
mbed SPI slave driver has no callback of interrupt processing. When the communication speed is too fast, the data set is not in time.
