9 years, 5 months ago.
nrf52 fails to export from online compiler.
I have tried to export a program for nrf52-dk to gcc under many different circumstances but in all cases have failed. Is nrf52 only supported with the online compiler then? The only gcc option is "Code Sourcery". That fails to export.
Here is an example program that fails to export: https://developer.mbed.org/users/andrewfelch/code/nrf52_cant_export_example/
I right-click the program and choose Export, Code Sourcery, and get the error which indicates to "Contact Support". In the best case I would also be able to export using the mbed-dev library (fails in both mbed library and mbed-dev library cases, so it seems no gcc-makeable export works).
-Andrew
