9 years, 6 months ago.
Pull mbed Device Connector Resource Observations - without Webhooks (Push)
Based on my current understanding, I need to subscribe to a resource in order to get notifications of changes from those resources through Webhooks ... this PUSH approach seams ok, if the resources change rather infrequently ... and I have a couple of devices in the field ...
If I am thinking about 1000s of devices with frequent delivery of changes this approach looks rather inefficient.
I would like to understand, if I can subscribe to resources, but directly access the (asynchronous) notifications of resources through the Rest Interface (PULL) of mbed Device Connector (without using Webhooks) - in order to stream the data e.g. into Apache Kafka for persistence and further processing.
Hi Rainer,
You sure can! mbed Device Connector supports long polling: https://docs.mbed.com/docs/mbed-device-connector-web-interfaces/en/latest/api-reference/#long-polling
Also be sure to check out the main mbed Device Connector Web Interfaces guide here: https://docs.mbed.com/docs/mbed-device-connector-web-interfaces/en/latest/. It talks a bit about long polling and notifications in general.
Hope that helps!
-Brian
Also, we've made some web libraries to make using mbed Device Connector even easier.
We have a Node.js library here: https://github.com/ARMmbed/mbed-connector-api-node
And a Python library here: https://github.com/ARMmbed/mbed-connector-api-python
posted by 30 Sep 2016Hi Brian,
thanks for feedback. I am aware of the outlined resources, and I was already playing around with mbed Client Java webapp outlined here: https://github.com/ARMmbed/mbed-webapp-example/.
Based on what I can see is that for long polling the app always reopens the connection after 25s with a "https://api.connector.mbed.com:443/v2/notification/pull"
In the mbed device connector api reference there is the following note:
It is mandatory to create a persistent connection, by sending the Connection: keep-alive header, to avoid excessive TLS handshakes
whenever I use curl though with
curl -s -H 'Connection: keep-alive' -H 'Authorization: Bearer <myBearer>' https://api.connector.mbed.com/v2/notification/pull
the commend breaks after the first notification.
Can you please elaborate on how I am getting a constant stream of events and keep the curl alive?
posted by 02 Oct 2016Hi Rainer,
Thanks for elaborating a bit on your question, I think I may have been a bit eager in my answer :)
If I understand your question now, it sounds like what you're asking for is something closer to a WebSocket connection? Where the connection is persistent but the data comes in as it's available? To my knowledge this kind of support does not exist in mbed Device Connector.
If I misunderstood your question (again!), would you mind clarifying a bit more?
Thanks,
Brian
posted by 02 Oct 2016Hi Brian,
thanks again for your feedback ...
Yes, I strongly believe that Device Connector has to deliver the incoming events either through
1) Server Sent Events (prefered) or
2) Websockets
If neither of this capabilities are available, then I don't see any commercial usage of Device Connector due to the overhead generated by the provided long polling and web hooks alternatives.
A good example on how this should work is particles "Device Connector" https://docs.particle.io/reference/api/#get-a-stream-of-your-events through Server Sent Events.
Is there a roadmap of mbed device connector where I can see what's coming in regards to functionality so I can adjust my plans accordingly?
posted by 03 Oct 2016
