9 years, 4 months ago.
i2c EEprom and mbed
Hi. I have some problems on using a Microchip i2c eeprom and mbed. If I add a lot of records (for me one record means 10 bytes), sometimes I have a very strange problem. For example if I write 10 bytes with pointer= 250, the bytes writtes are ok but I have a corruption problem with bytes ad pointer= 130, written some time before. Do you have a idea non that? The code is very short:
        Buffer[0]= (EEPROMPointer >> 8) & 0xff;
        Buffer[1]= EEPROMPointer & 0xff;
        Buffer[2]= Channel;
        Buffer[3]= (Code >> 24) & 0xff;
        Buffer[4]= (Code >> 16) & 0xff;
        Buffer[5]= (Code >> 8) & 0xff;
        Buffer[6]= Code & 0xff;
        Buffer[7]= 0xff;
        Buffer[8]= 0xff;
        Buffer[9]= 0xff;
        Buffer[10]= 0xff;
        Buffer[11]= 0xff;
                if (!i2c.write(SlaveAddress, (char*)Buffer, sizeof(Buffer))== 0) return false;
                while(i2c.write(SlaveAddress, NULL, 0));
Your Buffer seems to have a size of at least 12 bytes since you write a value to Buffer[11].
So the i2c.write(SlaveAddress, (char*)Buffer, sizeof(Buffer) operation will write more than 10 bytes. Maybe that causes corruption.
What is the purpose of
That NULL operation may cause a problem (eg spurious I2C Start) depending on the platform implementation of I2C.write.
That line of code is necessary to wait till the end of the i2c bus operations. There is a problem with the new mbed revision (127). The i2c bus does not work! Downgrading to 126 now the i2c bus works. The problem is evident with ST Nucleo F446RE
posted by Denis Gottardello 04 Oct 2016
Hi Denis with mbed_130, I don't think that the line below is needed anymore ... while(i2c.write(SlaveAddress, NULL, 0)); actually, this could even cause an error in the I2C lib, I will test and send a correction for this
posted by Laurent Meunier 29 Nov 2016
