9 years, 6 months ago.
Command window for UART?
Is there any command window in order to communicate with the microcontroller? If there is , then where can i find it. I downloaded putty and tried but its not working?
Hi Sachin,
What platform are you using? If you're using an ST platform you'll need to install the ST Link driver, which you can find here: https://developer.mbed.org/teams/ST/wiki/ST-Link-Driver
If you're using any other platform you should be able to just install the mbed Serial driver: https://developer.mbed.org/handbook/Windows-serial-configuration
Let me know if that helps!
Thanks,
Brian
