9 years, 6 months ago.
Seeing RTC error: RTC initialization failed on new mDot modules
Can anyone tell me what the error RTC error: RTC initialization failed means and how to get rid of it. This occurs after flashing new firmware to a brand new mDot and has happened on at least 3 brand new mDots now. This is not version specific as it happens with the latest libmDot and previous release.
The exact same code runs correctly on an older mDot purchased at a different time.
Do I have a bad batch or is this fixable?
Thanks
Andrew
Andrew,
Do you still see the error if you completely remove power from the mDot after flashing?
Cheers,
Mike
posted by Mike Fiore 27 Sep 2016Yes. mDots have been powered off, back on, still same message when it starts to access the mDot library. Repeated this on 3 mDots. I have another 11 to try but holding off in case there is some other issue.
I'll give them another try later to double check.
Andrew
posted by Andrew Lindsay 27 Sep 2016Retried all this with the same mDots which now worked and the rest of my mDots, giving a total of 15. All now work. Thanks for your help Mike.
Andrew
posted by Andrew Lindsay 28 Sep 2016
