10 years, 11 months ago.
WatchDog LPC1347
Hello all;
More problems with LPC1347, This time it is the watchdog,
// data sheet: http://www.nxp.com/documents/user_manual/UM10524.pdf
//DigitalOut myled1 (P1_2);
//DigitalOut myled2 (P1_5);
DigitalOut myled3 (P1_28);
DigitalOut myled4 (P0_7);
class Watchdog {
public:
void kick(float s)
// 3.5.8 Watchdog oscillator control register
LPC_SYSCON->WDTOSCCTRL = 0x0021; //
// 0x0024;// 0.6 mhz/4 ??
// 0x003f; // 0.6 Mhz / 64 -> ?? 0.106667 mS
// 15.8.5 Watchdog Clock Select register
LPC_WWDT->CLKSEL = 0x01; // Set CLK src to Watcdog osc
//uint32_t clk = SystemCoreClock / 16; // WD has a fixed /4 prescaler, PCLK default is /4
//LPC_WDT->WDTC = s * (float)clk;
LPC_WWDT->TC = 9375; // ?? 1 second
LPC_WWDT->MOD = 0x3; // Enabled and Reset
LPC_WWDT->FEED = 0xAA;
LPC_WWDT->FEED = 0x55;
void feed() {
// LPC_WWDT->FEED = 0xAA;
// LPC_WWDT->FEED = 0x55;
Watchdog w;
printf("Hello World!\r\n");
w.kick(2.5);
int hang = 0;
int ReadCountDown;
while(1)
//printf("loop...%d\r\n",hang);
float h = hang / 10.0;
ReadCountDown = LPC_WWDT->TV;
// printf("ok T:%4.3f %d\r\n",h,ReadCountDown); // logging program
printf("%d %d\r\n",hang, ReadCountDown);
wait(0.1);
myled3 = !myled3;
if (hang == 30)
// w.feed();
LPC_WWDT->FEED = 0x33; // force reset by wrong food !!
printf ("\r\n Cat Food !!\r\n");
else
myled4 = !myled3;
if (hang > 150) hang = 10;
hang++;
I copied the example from Simon's Watchdog code from - http://mbed.org/forum/mbed/topic/508/
Changed some of the defines to match (compile) those in LPC13Uxx.h
but It does not work,
If I read the TC value, which should be decremented, it is fixed at 255 (default)
if I feed WatchDog with Cat food, no RESET is generated :(
As you can see, in the code, I NEVER feed the dog !!!
Still no reset ??
I know I must be doing some thing wrong, but what ??
Pleas any one ??
Ceri
Try adding at the start:
LPC_SYSCON->SYSAHBCLKCTRL |= 0x8000;
That enables clock for the registers of the watchdog.
In general example code for LPC11u24 WDT for a different purpose (waking from deepsleep): https://developer.mbed.org/users/Sissors/code/WakeUp/file/f3adba7cf7c4/Device/WakeUp_LPC11u24.cpp
Thanks,
it does appear to work now with IRC clock,
Timer t;
class Watchdog {
public:
void kick(float s)
// Table 268. Register overview: Watchdog timer (base address 0x4000 4000)
// 3.5.14 System clock control register (SYSAHBCLKCTRL)
LPC_WWDT->CLKSEL = 0x00; // Set CLK src to 12MHZ - Watcdog osc
LPC_WWDT->TC = 3000000; // 9375; // ?? 1 second
void feed() {
Watchdog w;
t.reset();
t.start();
printf("\r\n\r\nHello World!\r\n");
w.kick(2.5);
int hang = 0;
int ReadCountDown;
while(1)
printf("%d %08x, %d mS .. \r\n",hang, ReadCountDown, t.read_ms());
wait(0.01);
myled3 = !myled3;
if (hang == 30)
// w.feed();
// LPC_WWDT->FEED = 0x33; // force reset by wrong food !!
// printf ("\r\n Cat Food !!\r\n");
else
myled4 = !myled3;
hang++;
this gives 990mS count @ 9600 Baud,
will try to get my oscilloscope on it later, and tweak to get a value - or possibly set to a time out !!!
Would also like to get watchdog timer to work, but this makes me happy :)
Cheers
Ceri
posted by 21 Apr 2015
