10 years, 11 months ago.
Getting Error L6218E in my program
Hi all,
I am trying to use the deepsleep and a wake-up timer in the LPC11U68 using LPCXpresso11U68 platform to compile it. I followed an example here but I keep getting the same error. Here is the code I have done so far (I imported the WakeUp library in my program folder):
Deepsleep and WakeUp timer
#include "WakeUp.h"
DigitalOut led(P2_2);
void deepsleep(void)
// PCON[PD] set to deepsleep
LPC_PMU->PCON = 0x1;
// SRC[SLEEPDEEP] set to 1 = deep sleep
SCB->SCR |= SCB_SCR_SLEEPDEEP_Msk;
// Power up everything after powerdown
LPC_SYSCON->PDAWAKECFG &= 0xFFFFF800;
// wait for interrupt
__WFI();
//The low-power oscillator can be quite inaccurate on some targets
//this function calibrates it against the main clock
WakeUp::calibrate();
led = 1;
wait(0.5);
led = 0;
//Set wakeup time for 2 seconds
WakeUp::set_ms(2000);
//Enter deepsleep, the program won't go beyond this point until it is woken up
deepsleep();
led = !led;
wait(1);
It blinks first and then enters in a sleep mode. After 2s, it should wake up and enter the while loop and blink the whole time. This is just to test the wakeup timer. However I keep getting the same errors (Error L6218E):
"Undefined symbol WakeUp::set_ms(unsigned) (referred from main.cpp.LPC11U68.o)" "Undefined symbol WakeUp::calibrate() (referred from main.cpp.LPC11U68.o)"
I tested before the deepsleep function with an external interrupt and it works perfectly. It is when I introduce the wake up that it happens those two errors. Please, anyone can help me out with this problem? Thanks anyway.
considering the WakeUp Library, if we look at the cpp files from Erik -> https://developer.mbed.org/users/Sissors/code/WakeUp/file/f3adba7cf7c4/Device
Each Wakeup....cpp file begins with an #ifdef TARGET_...
So, there 2 possibilities :
-1- this library isn't for your platform -2- try to use the good Define to allow it to compile.
As actually no define is related to your platform, then the cpp code isn't compiled and then the linker can not find this code to link it with the main.
The most likely code that can be re-used is that of the LPC11u24. So in the LPC11u24 file in the WakeUp library replace the #ifdef TARGET_LPC11U24, by #ifdef TARGET_LPC11U68.
Please report back if that compiles and if it works. If yes I will add it to the library. But I don't have the 11u68 myself so I cannot test it.
