9 years, 6 months ago. This question has been closed. Reason: Duplicate question
Which version of ARM compiler are you using?
I didn't see any problem with MDK-ARM v5.21a (ARM compiler v5.06 update 3).
Thanks for your support I'm using MDK-ARM V5.13.0.0.
If I removed few lines from FunctionPointer.h file then it works and able to compile and build the library. These are the lines: MBED_DEPRECATED_SINCE("mbed-os-5.1", "FunctionPointerArg1<R, A> has been replaced by Callback<R(A)>")
Path for this file os :\mbed-os-latest\hal\api\FunctionPointer.h
One more thing : same library if I build using IAR, without any error I'm able to build library..!! This problem is only using ARM.
So,Please Help me for this. Thanks
posted by 26 Sep 2016The MDK v5.13 uses ARM compiler 5.05u1 (build 106) which is not latest version. I recommend to update MDK-ARM v5.21 since there was behavior change between ARM compiler 5.05 and 5.06 below (The attribute deprecated now takes a parameter in GNU mode).
ARM Compiler 5.05: http://infocenter.arm.com/help/topic/com.arm.doc.dui0472k/chr1359124974790.html
ARM Compiler 5.06: http://infocenter.arm.com/help/topic/com.arm.doc.dui0472m/chr1359124974790.html
posted by 27 Sep 2016
