9 years, 5 months ago.
mDot with DHT22 temperature/humidity sensor?
Hi, I'm having trouble getting the DHT22 temperature/humidity sensor to work with the mDot. I've proven that the circuit and library for the DHT sensor works on a ST Nucleo board and I'm able to get temperature and humidity readings. I have a pull up resistor on the DHT sensor data line.
But on the mDot, I get zero for humidity and (oddly) 32 for temperature on the F scale. I get those same values if I remove the sensor's data wire from the mDot.
I'm using this library: https://developer.mbed.org/users/Wimpie/code/DHT/
In the code below, I'm able to see the sanity check value correctly, but the temperature and humidity comes back as 32 and 0, respectively.
#include "DHT.h"
DHT mydht22(PC_1,DHT22); // DHT22 on Pin 16.  I've also tried PA_7, pin 11.
        float test = 60.3;  //sanity check
        float mytemp = mydht22.ReadTemperature(FARENHEIT);  //value=32 all the time
        float myhum= mydht22.ReadHumidity(); //value=0 all the time
The MultiConnect® mDot™ offers significantly longer range and improved radio performance compared to traditional wireless solutions—resulting in greater transmission range and reduced capital expense.
typo in the comment. PC_1 is pin 15, not 16. It was wired correctly, just commented incorrectly.
posted by Eric Tsai 20 Sep 2016
