9 years, 6 months ago.
Problems when communicating with UART& I2C interfaces
Hello guys,
please I need Help! I have NUCLEOF401RE board which I want to connect it with - DHT22 (Temperature & Humidity sensor) via PA_8 as GPIO where DHT22 spits out a digital signal on the data pin. using this code https://developer.mbed.org/teams/Skovbrynet/code/DHT22tester/ - BMP180 (Pressure & Temperature sensor) via I2C interface (PB_8/ I2C_SCL, PB_9/I2C_SDA). using this code https://developer.mbed.org/users/mikawataru/code/nucleo_BMP180/ - ESP8226 (wifi module) via UART_1 interface (PA_9, PA_10). using this code https://developer.mbed.org/teams/components/code/HelloESP8266Interface/ I working with Ubuntu, mbed OS.5, and minicom as serial console. I am getting no values/ results carried out from the serial interface or from the I2C interface!
from the DHT22 sensor I got this output:
from the BMP180 I got this output:
from the ESP8226 I got this output:
So in all cases I am getting no results! the baudrate is always set to 9600 in all of the examples.
Anyone knows what might be the problem?
