9 years, 6 months ago.
RS232 Frame error
I'm trying to communicate over RS232 with some pins on my Nucleo F070RB. According to the pinout, pins PC_10 and PC_11 can be used for RS232 communication. I currently send only the character "C". I've connected my own USB-2-serial box to the pins (tx,rx,gnd). The Terminal on my PC is not showing the correct character... It says that there is a FRAME ERROR. Debugging the ascii on the scope, I can see 0x43 appearing and this should be correct according to the ascii-table. But in the Terminal I'm getting: ^<0>
All my settings are set the same: br: 9600, data:8, par: none, stop: 1 (also in config of the hardware usb-2-rs232-box)
Connection through USBTX and USBRX of the mbed is working fine, but then I'm not using the external hardware usb-2-rs232 box)
I2C i2c(I2C_SDA, I2C_SCL);
//Serial pc(USBTX,USBRX); tx,rx
Serial device(PC_10, PC_11);
DigitalOut myled(LED2);
DigitalIn mybutton(USER_BUTTON);
device.baud(9600);
device.format(8,SerialBase::None,1);
while (1) {
if (device.readable() == 1) {
myled=1;
device.printf("C");
myled = 0;
wait(0.5);
} else {
myled = 1;
wait(2);
myled = 0;
wait(1);
