9 years, 5 months ago.
ESP8266 Uploading Problem
Im currently trying to upload data onto phant , but I cant. I keep getting a busy p... error on the terminal , and finally ERROR. I cant seem to figure out where exactly am I going wrong , since I am new to AT commands. Where could I possibly be going wrong , and what can I do to rectify the error ?
Do you get 'busy p' straight away or after a command? If straight away, pull the reset pin on the ESP8266 low and try again.
If it happens after a command we'd need to see the AT history, but probably better to ask at the ESP8266 forum.
Im sending a bunch of commands together. In short , Im using a predefined code , so spotting the error is diffcult. Do I still need to pull the reset pin to low?
posted by Swiss Gear 05 Sep 2016
Then start doing the AT commands command by command, and see what goes wrong. You can run https://developer.mbed.org/users/mbedAustin/code/SerialPassthrough/ on your board and forward data to ESP8266 to communicate directly from computer->ESP8266. This way you can run the AT commands over serial and figure out what goes wrong.
posted by Jan Jongboom 05 Sep 2016
