10 years, 12 months ago.
SPISlave is note replying to spidev
Hi , I am trying to connect a beaglebone with spidev interface to STM32F411RE Nucleo board using spi. Master: beaglebone (spidev linux driver) Slave :STM32F411RE Nucleo mbed board.
Heres my code SPI Master:
*Filename : spi_test.c
*Purpose : this file sends a byte data and recieves a signle byte.
#include <stdint.h>
#include <stdio.h>
#include <unistd.h>
#include <stdlib.h>
#include <fcntl.h>
#include <string.h>
#include <sys/ioctl.h>
#include <sys/types.h>
#include <sys/stat.h>
#include <linux/types.h>
#include <linux/spi/spidev.h>
void spi_init(int fd)
uint8_t tx=0xdd;
uint8_t rx=10;
int ret;
struct spi_ioc_transfer xfer;
xfer.tx_buf= (unsigned long)&tx;
xfer.rx_buf= (unsigned long)℞
xfer.len = 1;
xfer.bits_per_word = 8;
xfer.speed_hz = 1000000;
//xfer.cs_change = 0;
ret=ioctl(fd,SPI_IOC_MESSAGE(1),&xfer);
if(ret < 1){
perror("Error while sending spi_messages");
exit(1);
printf("rx:%x\n",rx);
int fd;
fd=open("/dev/spidev1.0",O_RDWR);
if(fd<0){
perror("Not able to open device file");
return -1;
while(1)
spi_init(fd);
return 0;
And Here is my SPI Slave Mbed Program:
//SPI Slave
SPISlave device(PA_7,PA_6,PA_5,PA_4); // mosi, miso, sclk, ssel
Serial pc(SERIAL_TX,SERIAL_RX);
device.format(8,0);
device.frequency(1000000);
printf("Program Starting\r\n");
device.reply(0x00); // Prime SPI with first reply
if(device.receive()) {
if(!ss){
int v = device.read(); // Read byte from master // Add one to it, modulo 256
device.reply(v);
printf("Read 0x%x Reply 0x%x",v,v);
using uart i am able to see the received byte but my master is not receiving any data. its just zeroing the buffers.
I suppose that tx and rx into spi_init shoud be array of char...
try with :
uint8_t tx[10]; uint8_t rx[10];
Look at the internet about spi examples with linux/raspberry, you will find a lot a sources.
