9 years, 6 months ago.
Can't find mbed.h when I compiled with GCC in Keil uVision5
Hello
I extracted project file from mbed platform. It is for offline debugging of over-sized(32k) source code. When I built the file, I faced to these errors.
it says lack of mbed.h, but there is actually the header file in the mbed folder. I got same error when I C&P the header file at same directory of x_nucleo_iks01a1.cpp.
does anyone know how to deal with this??
compilerErrorMessage
compiling x_nucleo_iks01a1.cpp...
X_NUCLEO_IKS01A1/mbed.h(29): error: fatal error: toolchain.h: No such file or directory
compiling hts221_class.cpp...
X_NUCLEO_IKS01A1/Components/hts221/hts221_class.h(42): error: fatal error: mbed.h: No such file or directory
compiling main.cpp...
main.cpp(18): error: fatal error: mbed.h: No such file or directory
compiling lis3mdl_class.cpp...
X_NUCLEO_IKS01A1/Components/lis3mdl/lis3mdl_class.h(42): error: fatal error: mbed.h: No such file or directory
compiling lsm6ds0_class.cpp...
X_NUCLEO_IKS01A1/Components/lsm6ds0/lsm6ds0_class.h(42): error: fatal error: mbed.h: No such file or directory
compiling lps25h_class.cpp...
X_NUCLEO_IKS01A1/Components/lps25h/lps25h_class.h(42): error: fatal error: mbed.h: No such file or directory
compiling lsm6ds3_class.cpp...
X_NUCLEO_IKS01A1/Components/lsm6ds3/lsm6ds3_class.h(42): error: fatal error: mbed.h: No such file or directory
Marchall
Hi Marchall,
Did you export to uVision or GCC?
posted by Andrea Corrado 05 Sep 2016
Hi Andrea, I exported the project to uVision4. Also tried uVision5.
posted by Marchall Oakbow 05 Sep 2016
I downloaded the other project, led_blink, and it also said "mbed.h: No such file or directory"
The header file problem is solved. I have forgot to edit the include path. But the next is the compiler doesnt recognize class objects and linking process. Is this because of "C" compiler? Does it compile C++ code includes class or moreover??
posted by Marchall Oakbow 06 Sep 2016
Hi Marchall,
Are you using mbed-os?
posted by Andrea Corrado 09 Sep 2016
Hi Andrea
I don't use mbed-os
posted by Marchall Oakbow 09 Sep 2016
Marchall,
Can you send the program you are trying to export to uVision?
This is the test code I tried compiling
  1. include "mbed.h"
DigitalOut myled(LED1);
int main() { while(1) { myled =! myled; LED is ON wait(1); } }
Once after start building the project, The uVision IDE went freeze and a window appeared to say "ld.exe has stopped"
The original code I pasted at first is kinda heavy, so I am trying to compile simple project with GCC in Keil.
Though it is too long, but I put the error message I got when I compiled the test code.
Rebuild target 'Nucleo_blink_led' compiling main.cpp... linking... c:/program files (x86)/gnu tools arm embedded/5.4 2016q2/bin/../lib/gcc/arm-none-eabi/5.4.1/../../../../arm-none-eabi/bin/ld.exe: error: mbed/TARGET_NUCLEO_F401RE/TOOLCHAIN_ARM_STD/cmsis_nvic.o uses VFP register arguments, ./Nucleo_blink_led.elf does not c:/program files (x86)/gnu tools arm embedded/5.4 2016q2/bin/../lib/gcc/arm-none-eabi/5.4.1/../../../../arm-none-eabi/bin/ld.exe: failed to merge target specific data of file mbed/TARGET_NUCLEO_F401RE/TOOLCHAIN_ARM_STD/cmsis_nvic.o c:/program files (x86)/gnu tools arm embedded/5.4 2016q2/bin/../lib/gcc/arm-none-eabi/5.4.1/../../../../arm-none-eabi/bin/ld.exe: error: mbed/TARGET_NUCLEO_F401RE/TOOLCHAIN_ARM_STD/hal_tick.o uses VFP register arguments, ./Nucleo_blink_led.elf does not c:/program files (x86)/gnu tools arm embedded/5.4 2016q2/bin/../lib/gcc/arm-none-eabi/5.4.1/../../../../arm-none-eabi/bin/ld.exe: failed to merge target specific data of file mbed/TARGET_NUCLEO_F401RE/TOOLCHAIN_ARM_STD/hal_tick.o c:/program files (x86)/gnu tools arm embedded/5.4 2016q2/bin/../lib/gcc/arm-none-eabi/5.4.1/../../../../arm-none-eabi/bin/ld.exe: error: mbed/TARGET_NUCLEO_F401RE/TOOLCHAIN_ARM_STD/system_stm32f4xx.o uses VFP register arguments, ./Nucleo_blink_led.elf does not c:/program files (x86)/gnu tools arm embedded/5.4 2016q2/bin/../lib/gcc/arm-none-eabi/5.4.1/../../../../arm-none-eabi/bin/ld.exe: failed to merge target specific data of file mbed/TARGET_NUCLEO_F401RE/TOOLCHAIN_ARM_STD/system_stm32f4xx.o collect2.exe: error: ld returned 255 exit status ".\Nucleo_blink_led.elf" - 1 Error(s), 0 Warning(s). Target not created. Build Time Elapsed: 00:00:30
After reading these error messages, the GCC Linker doesnt work because it lacks of .lib files or something else?? Maybe the ones exported as gcc have.
