9 years, 7 months ago.
Weird problem. Extraputty print out every 10~20seconds.
debugging
int a;
wait(1);
a = a + 1;
printf("%d", a);
LED=!LED;
I'm encountering this weird problem with ExtraPutty. It will only display datas every 10 to 20seconds. Set baud rate to 9600, 8bit, 1 stop bit, parity none, flow control XON/XOFF Any help?
Hi WB Tan,
This is usually caused because the buffer isn't being flushed between each printf. The way to ensure it gets flushed each time is to print a new line character ('\n') at the end of the string.
So your line:
printf("%d", a);
If you change it to:
printf("%d\n", a);
or for Windows terminals
printf("%d\r\n", a);
You should see it print every second.
Hope that helps!
-Brian
Why was this ever changed? I ran into the same issue and it does not make sense. I know that RawSerial will correct this but could you explain? Thanks.
posted by 31 Aug 2016
