13 years, 3 months ago.
Is it possible to run an ".exe" file through mbed?
If i make an executable program in visual basic, is it possible to run that program directly by writing some commands in mbed.
No. Visual Basic produces code that can be executed on a PC compatible computer. Visual Basic .NET needs .NET to be installed on the PC. The mbed won't do either.
There are boards out there like the netduino or Gadgeteer which can execute programs written using Visual Studio using the .NET micro framework which is a cut down version of .NET for microcontrollers. See http://netduino.com/ and http://www.netmf.com/gadgeteer/.
As Stephen says below, there are ways to trigger a PC program. I played around using the serial debug link for this purpose with VB to get the mbed controlling the actions of the VB program. It didn't actually run the VB program which I started manually, but it did control its funtion.
posted by Kevin Hobbs 24 Nov 2012kindly explain how to control its function
posted by Noman Malik 27 Nov 2012Many users have reported that they found error of https://unfitpc.com/ctfmon-exe when there are working on their computers but you just feel free and correct it easily .
posted by simran sidhki 05 Oct 2018
