9 years, 6 months ago.
how to define a function in another .c file?
I have main.c and test.c and I can't access a function in test.c by main.c
I get this error: Error: Undefined symbol blah() (referred from main.NUCLEO_F091RC.o).
main.c has: ... extern void blah( void );
void blahblah( void ) { blah(); }
test.c has:
void blah( void ) { int a=5; int b=5*5; }
Both files are within the project folder, and not within any subfolder.
Hello Dough,
I have tested your code and it compiles smoothly with no errors. Please check the file names in your project because when I rename main.c to main.cpp then I get the same error as you have reported. It's because C++ is using name mangling. The solution is
  • tell the compiler that blah() is not a C++ but C function as follows:
main.cpp
extern "C" void blah(void);
     blah();
  • or rename also test.c to test.cpp and then blah() will be compiled as a C++ function.
