9 years, 6 months ago.
Changing name of test affects whether it passes or fails
When I use the example test file, delete my .build folder, delete every other folder in TESTS and run it with -n test-name-here a particular test fails unless its file name is EXACTLY the same as the example.
In this case if I rename the sample-test folder to sample-test2 run
mbed test -n tests-sample-test-group-sample-test2 -t GCC_ARM -m LPC1768
it fails with a TIMEOUT error and doesn't display a list of the tests in the file
If I put the folder name back and run
-n tests-sample-test-group-sample-test -t GCC_ARM -m LPC1768
it succeeds in showing the two tests, OK and FAIL, but more importantly it actually shows a list of the tests in the file.
Consider below terminal output shasum of build file is same, there is no logical reason why anything different should happen
Kyles-MacBook-Pro:sample-test-group kvanb$ shasum sample-test/sample-test.bin 63aed24d0793403122a82310ab179b17cc64461b sample-test/sample-test.bin Kyles-MacBook-Pro:sample-test-group kvanb$ shasum sample-test2/sample-test2.bin 63aed24d0793403122a82310ab179b17cc64461b sample-test2/sample-test2.bin
I have power cycled the device multiple times
Full output of fail
> mbedgt: greentea test automation tool ver. 1.2.0 > mbedgt: test specification file '/Users/kvanb/git/ams-test-cyclic/.build/tests/LPC1768/GCC_ARM/test_spec.json' (specified with > --test-spec option) > mbedgt: using '/Users/kvanb/git/ams-test-cyclic/.build/tests/LPC1768/GCC_ARM/test_spec.json' from current directory! > mbedgt: detecting connected mbed-enabled devices... > mbedgt: detected 1 device > mbedgt: processing target 'LPC1768' toolchain 'GCC_ARM' compatible platforms... (note: switch set to --parallel 1) > mbedgt: test case filter (specified with -n option) > test filtered in 'tests-sample-test-group-sample-test2' > mbedgt: running 1 test for platform 'LPC1768' and toolchain 'GCC_ARM' > mbedgt: mbed-host-test-runner: started > mbedgt: checking for GCOV data... > mbedgt: test case summary event not found > no test case report present, assuming test suite to be a single test case! > test suite: tests-sample-test-group-sample-test2 > test case: group-sample-test2 > mbedgt: test on hardware with target id: 101000000000000000000002F7F214D673a6e4da75be38e5bd6bae3b02404c58 > mbedgt: test suite 'tests-sample-test-group-sample-test2' ............................................ TIMEOUT in 64.39 sec > test case: 'group-sample-test2' .............................................................. ERROR in 64.39 sec > mbedgt: test case summary: 0 passes, 1 failure > mbedgt: all tests finished! > mbedgt: shuffle seed: 0.1821426898 > mbedgt: test suite report: > +-----------------+---------------+--------------------------------------+---------+--------------------+-------------+ > | target | platform_name | test suite | result | elapsed_time (sec) | copy_method | > +-----------------+---------------+--------------------------------------+---------+--------------------+-------------+ > | LPC1768-GCC_ARM | LPC1768 | tests-sample-test-group-sample-test2 | TIMEOUT | 64.39 | shell | > +-----------------+---------------+--------------------------------------+---------+--------------------+-------------+ > mbedgt: test suite results: 1 TIMEOUT > mbedgt: test case report: > +-----------------+---------------+--------------------------------------+--------------------+--------+--------+--------+---------> -----------+ > | target | platform_name | test suite | test case | passed | failed | result | > elapsed_time (sec) | > +-----------------+---------------+--------------------------------------+--------------------+--------+--------+--------+---------> -----------+ > | LPC1768-GCC_ARM | LPC1768 | tests-sample-test-group-sample-test2 | group-sample-test2 | 0 | 1 | ERROR | > 64.39 | > +-----------------+---------------+--------------------------------------+--------------------+--------+--------+--------+---------> -----------+ > mbedgt: test case results: 1 ERROR > mbedgt: completed in 64.58 sec > mbedgt: exited with code 1 > [mbed] ERROR: "mbedgt" returned error code 1. > [mbed] ERROR: Command "mbedgt --test-spec /Users/kvanb/git/ams-test-cyclic/.build/tests/LPC1768/GCC_ARM/test_spec.json -n > tests-sample-test-group-sample-test2" in "/Users/kvanb/git/ams-test-cyclic"
8 years, 11 months ago.
Was a bug ever filed on this? I ran into this same problem today and spent many hours puzzling over it until I cam across this thread. Deleting all the *.bin's on the MBED device (LPC1768) resolved the problem.
I have just posted a bug for it https://github.com/ARMmbed/mbed-os/issues/4130
posted by 07 Apr 2017
I think the mbed device ran out of space and that particular file name was working because the .bin file was already on the device, along with a LOT of other bin files. Any other file names were failing perhaps because the copy failed? Should this be a bug, perhaps it should report with a copy failed error message? Now that I have cleared out the lot of bin files it's working perfectly again with any file name
posted by Kyle Van Berendonck 24 Aug 2016Could you file a bug at https://github.com/ARMmbed/mbed-os ?
posted by Jan Jongboom 24 Aug 2016
