9 years, 5 months ago.
Linker Error L6236E with uVision 5 with blinky code.
Hi All, I am using the following compiler and IDE to build the blinky project:
uVision v5.17 and armcc v5.06 update 1
When I export the project to uvision 5 and build it, I am getting this error.
..\..\mbed-os\hal\targets\cmsis\TARGET_STM\TARGET_STM32F4\TARGET_NUCLEO_F401RE\TOOLCHAIN_ARM_STD\stm32f401xe.sct(34): error: L6236E: No section matches selector - no section to be FIRST/LAST.
Has anyone encountered this before. Looks like very basic issue to me?
Cheers, Jain.
F401RE target, what revision of mbed lib ? or mbed-dev used ? how do you export, from the online ide?
This error means there are two linker files (for instance), I had it when I had mbed 2x in my project (sources and mbed library), or missing linker file.
posted by Martin Kojtal 24 Aug 2016I could make it work. I think the export is not adding the assembler files for some reason. I added the startup and SVC_Table.s manually and it could build just fine.
posted by Vineet Jain 24 Aug 2016Ill have a look at this, thanks for reporting
posted by Martin Kojtal 25 Aug 2016
