9 years, 7 months ago.
function usage in the common folder in mbed library
Hi Andrea,
May I ask you about how to use functions in the c/c++ files in the common folder in mbed library? I have compiled my code and looks like having errors. I have a few questions below:
1, in my example, I'm using BusOut::write(), BusOut::write(), BusIn::read() etc functions, it looks like I do NOT need to re-declare before my Main program. right? but if not declared, it still shows the message : "Error: A nonstatic member reference must be relative to a specific object in "main.cpp", Line: 68, Col: 6". How to correctly use the functions from the common folder in the library? and I'm wondering if I did something wrong.
2, not sure why the Help in the error numbers return 404 Page Not found.
Thank you,
Daniel L
Hi Daniel,
You may find the documentation page and example program located here helpful: https://docs.mbed.com/docs/mbed-os-api-reference/en/5.1/APIs/io/BusOut/
Hope that helps!
-Brian
Daniel,
Thanks for your question.
You're syntax for calling the member function are incorrect, you should be calling BusOut.write ().
Look at:
http://www.tutorialspoint.com/cplusplus/cpp_class_member_functions.htm
Andrea, team mbed
posted by Andrea Corrado 18 Aug 2016Thanks Andrea, I'll look at it. Cheers, Daniel Liu
posted by Daniel Liu 18 Aug 2016
