9 years, 7 months ago.
USBKeyboard emulator waiting for USB connection based on position of C code on LPC1768
I'm using an LPC1768 to emulate a USB keyboard together with some HID stuff. All well and good and it works fine using the standard USB lines on p31/p32.
However in my real code I have a lot of functions that use keyboard.printf's say. That is above the main().
If I define:
USBKeyboard keyboard;
above main() the functions work fine. I've produced a simple working example below which calls SayHello() and types something out.
1 * The issue is that main() isn't entered into unless the keyboard emulator is plugged in to my PC from pins p31/p32. It just sticks, i.e. it's blocking.
2 * I can resolve this by having the USBKeyboard keyboard def in main() and then doing it from there. However again once activated it stops (blocking) for a USB lead to be plugged into the PC.
Option 2 would be fine as what I really want to do is enable the keyboard HID at will based on a config file on the mbed flash drive letter. BUT I can't do this as I have a ton of functions above main() that use the keyboard which is no longer defined at the top. So it won't compile.
Anyone any ideas as I really don't want to start modifying the USBHID and USBKeyboard code unless I really have to?
Don't forget at the moment none of my code executes until the USB lead is plugged in. There also doesn't seem to be a timeout for non connection to USB in USBKeyboard.h. Or have I missed something...
Richards simple example
#include "USBKeyboard.h"
HID_REPORT report;
DigitalOut DebugLED(LED4);
void SayHello()
    keyboard.printf("Hello World from Mbed\r\n");
    DebugLED = 1;
    wait(4);
    //USBKeyboard keyboard;
    //keyboard.printf("Hello World from Mbed\r\n");
    SayHello();
